Cat D-3B steering clutch friction discs
Den in BC
06-06-2006 14:51:36
Does anyone know how many broken fibre drive teeth on a steering clutch pack friction disc group is acceptable per disc for a D-3B non-oil cooled set-up?New Cat disks are too expensive to buy!
Also, has anyone used any of the aftermarket fibre discs and steel plates on there machines?
Thanks Den
Bob Plumadore
06-07-2006 05:06:08
 Re: Cat D-3B steering clutch friction discs in reply to Den in BC, 06-06-2006 14:51:36
2 or 3 teeth missing want hurt, I have had good luck with aftermarket clutch disc.
Den in BC
06-14-2006 12:24:25
 Re: Cat D-3B steering clutch friction discs in reply to Bob Plumadore, 06-07-2006 05:06:08
Thanks for your reply,I bought aftermarket frictions discs and steel plates.However, I believe I have been shipped the wrong steel plates because they do not have a tapered lug to fit the taper in the drive drum,they are instead a square lug with contact only at the corners of the lugs to the drive drum.
These plates can't be right,what do you think?
Thanks, Den in BC
Bob Plumadore
06-14-2006 13:35:26
 Re: Cat D-3B steering clutch friction discs in reply to Den in BC, 06-14-2006 12:24:25
you are probably right, I would contact the supplier.E mail me I may be able to help you. I have worked on these toys since the time they came out. rplumadore@comcast.net
Den in BC
06-15-2006 08:20:19
 Re: Cat D-3B steering clutch friction discs in reply to Bob Plumadore, 06-14-2006 13:35:26
Bob,
I did contact the supplier and after some investigation on his part as well as mine with the local cat dealer,I was shipped the wrong plates.All has been righted now.
Den in BC
John/Pa
06-10-2006 03:44:32
 Bob in reply to Bob Plumadore, 06-07-2006 05:06:08
I had posted a while back looking for a fan for a D8. You replied that you had a couple. Saw the fellow who owns the D8 the other day and he informed me he aquired one. So, thanks for your help. John
