Kom. D31 Battery Install
J Turpin
06-10-2006 18:09:13
I have a D31-16 that I took the batteries out of last fall. They had the + cable going to + terminal. The had a jumper between the negative on the same battery and the + on the second battery. The - on the second battery was then grounded. Does this sound right? I don't want to do any welding :)
JT in NC
Tractor Dan
06-11-2006 14:57:40
 Re: Kom. D31 Battery Install in reply to J Turpin , 06-10-2006 18:09:13
that sounds right mine d31a-17 is 24 volt ground to - + of that goes to - of other then + to positive
DWF
06-10-2006 19:38:53
It sounds as though you have a 24 volt system. DWF
