JD transmission question
jkloepping
06-12-2006 22:29:14
When the clutch packs in the JD transmission finally wear out, will the machine stop moving before the discs start wearing metal-to-metal, once the frictio nmaterial is all used up?
What about the steering clutches?
Roy Suomi
06-13-2006 21:23:19
 Re: JD transmission question in reply to jkloepping, 06-12-2006 22:29:14
Transmission an wet steering clutches usually have a sintered bronze composite bonded to the clutch plates or fiber plates .Usually what stops a transmission or steering clutch is a loss of pressure causing of a burning of plates. Wrong oil used in the system can cause premature wear from not having the correct additives for brakes and clutches..Once in a while one might think the trans or steer clutch is kaput...sometimes a simple adjustment can lengthen service of unit.
