JD450 fuel tank question
motorhead460
06-15-2006 18:03:06
Hi when I run my dozer for a few minutes and loosen the fuel cap it has a little vacuum,if I run it for a few hours it has quite a lot of vacuum to it,is this normal or should there be a vent hole somewhere that might be stopped up.Thanks
Roy Suomi
06-16-2006 20:03:57
 Re: JD450 fuel tank question in reply to motorhead460, 06-15-2006 18:03:06
There is a vent built into the tank..If you look at the bottom of the tank you will find a weldment by itself..there should be a hole in the center of that weldment..This is a tube that goes to the top of the tank for venting...
motorhead460
06-18-2006 17:40:44
 Re: JD450 fuel tank question in reply to Roy Suomi, 06-16-2006 20:03:57
Thanks Roy,I found the weldment as you described and it looks as if it has been smashed off and someone has welded it up solid.So now I think I"ll just add a little cintered filter like some of the chainsaws use to the filler cap,that should keep debris out and allow enough air into the tank.Thanks again,Rick
meadova
06-15-2006 19:12:41
My 350 does the same thing. Been running for years.
