1150B reverse
Pliantman
06-18-2006 10:09:18
After running 1150B dozer for an hour the right side steering pedel quits working when in reverse. Dozer pushes good, steers going forward both directions, pulls good in reverse but quits steering to the right in reverse after about an hour of hard pushing. Changed filters and oil but didn't help....any suggestions??
JCSinGA
06-20-2006 11:30:11
 Re: 1150B reverse in reply to Pliantman, 06-18-2006 10:09:18
I went around with an 1150B Case dozer for about a month with a similar problem. I was into the tranny twice, control valves and gaskets you name it I done it I thought.
My machine would quit pulling on one side after about 30 minutes and although I checked the control valve hoses with air pressure I didn't do it when the machine was warm when they had collapsed inside. So to make a long story short I wasted alot of time and money on a $15 hose.
Your problem is a little different than the one I had but it might pay you to go ahead and check the hoses.
