International Crawler 500
Danny McClure
06-18-2006 18:12:30
Need help in figureing out the problem,
crawler won't pull, transmission gears work good, will move forward and reverse sometimes, and stops, and makes a whinning noise. DOn't know where to start in fixing the problem.
Randy Wooley
06-25-2006 15:57:00
 Re: International Crawler 500 in reply to Danny McClure, 06-18-2006 18:12:30
do you have direct(clutch) or hydraulic (reverser)the 500 used both if you have reverser there are preasure readings generaly 20psi not moving 74psi clutches engaged
Randy
Kurt H.
06-19-2006 05:35:02
Are the clutchs properly adjusted? Mine will chatter, whine when they slip under a load.
