Case450 crawler faster on one side
Case450
06-21-2006 09:25:41
when i'm driving the machine in a straight line (or attempt to) it pulls to the right (drivers seat directions). Not a lot but doing long straight grades require some adjustment as you go along. Is this something I can adjust or is this going to be a major problem?
murray
06-25-2006 06:16:18
 Re: Case450 crawler faster on one side in reply to Case450, 06-21-2006 09:25:41
sounds like one track is wore more than the other. Hence if one track is longer because of pin wear it will travel farther every revolution. No its not a big concern just annoying but every crawler we have had does this as they get more time on the tracks. Our D5 cat with SALT tracks still runs straight but they don't wear like dry bushings. We had a MF 300 once that we had a replacement sprocket ring welded on and they didn't get it round. Now that was interesting as it would sway one way then the other.
