Breather tube smoke
Doug Hiatt
06-21-2006 09:45:31
My JD350B has started to produce a light amount of smoke from the breather tube. It will smoke for about three or four minutes then run clean for about five minutes. Oil level is on full air cleaner clean. Is there a mesh screen somewhere that completes the breathing system??
ebbsspeed
06-21-2006 12:30:56
 Re: Breather tube smoke in reply to Doug Hiatt, 06-21-2006 09:45:31
If you're just getting a little smoke I wouldn't be concerned. That's exactly what the breather tube is for, to vent out the combustion gasses (hence smoke) that gets by the rings. Just a little is a good thing; if you had a tired engine it would likely be blowing out pretty good especially under a load.
