Case 450 v Dresser TD7
Jeffie
06-21-2006 20:46:56
I currently have a TD7e,but am looking at getting
a Case 450c.
The Case seems like a smaller machine, blade certainly isnt as big as the TD7.
Anyone have any comparision info to share?
I cant seem to find any specs on either
(Like weight and HP).
Robert in W. Mi.
06-22-2006 20:04:51
 Re: Case 450 v Dresser TD7 in reply to Jeffie, 06-21-2006 20:46:56
I like my Case 450, but the TD-7 is a bigger heavier machine. If you need the extra weight and power of the bigger machine, then that's your best choise...
Robert
Jeffie
06-23-2006 05:09:44
 Re: Case 450 v Dresser TD7 in reply to Robert in W. Mi., 06-22-2006 20:04:51
Dont know if I "need" the extra weight/power.
On one hand, I lose (weight/power), on
the other hand, I'm getting a much
newer machine.
My TD7 is getting a bit long in the tooth
and probably needs a rebuild of the motor.
So its like spend 6k on a rebuild, or upgrade.
Larry from Mi.
06-22-2006 05:10:25
I had a Case 450C. The weight is about 12000#. The machine has 63 HP. My Dresser is a TD7G. It weighs 14000# and it is 70 HP. I replaced the injector pump and they can turn it up 10%. So I have 77 HP. What a difference. Go with the Dresser. Larry
