jcb 1400b stuck in gear
longdsc
06-23-2006 16:03:47
my jcb 1400b shuttle shift trans is stuck in 3rd gear shifter moves around but will not come out of gear. forward and reverse work, shifter allways did have alot play any ideas
thanks rich
ajk
06-26-2006 12:06:03
 Re: jcb 1400b stuck in gear in reply to longdsc, 06-23-2006 16:03:47
If you got the Borg Warner shuttle setup with a four speed box behind it I seem to remember that the gear shift lever is in two pieces, have a look under the boot around the lever and see that the clamp is tight,if the trouble is inside the box it can be removed on its own,just take the prop and handbrake disc off and loosen the bolts and lower it on a trolly jack,its a simple four speed box Spicer I think,your selectors may be worn,I see so much stuff on a daily basis that I cannot remember exactly whats under the lever but I would try to remove it first and line up the selectors,it may be that the lever is worn.
AJ
