Nonsense
jdemaris
06-23-2006 16:13:31
That is just plain not true. Button head fittings have been used for years in factory equipment - some only allowed to be lubed with food-grade grease. The button-head has no better (or worse) ability to hold grease or oil then a zerk fitting does. It does, however, allow one handed pumping and also handles getting hit by rocks and debris much better since it is not pointed. Deere, as well as many other tractor companies sold grease absolutely specific for their track rollers and idler wheels with button-head fittings. Deere started out recommending gear oil until the mid-60s, and then changed the recommendation over to grease except for extreme cold conditions. They found out that gear oil leaks out too fast once a small leak develops. That's why they sold what used to be labeled as "Track and Roller" grease, and is now sold as "Corn Head" grease. Oil was never recommended again until the new type "face seals" were developed for use in undercarriage parts. They can handle moderate wear and still hold oil, unlike the older style seals.
