Case G188D oil pump
jkloepping
06-24-2006 23:16:14
My oil pump checks out but for two things. There seems to be quite a bit of play in the shaft attached to the drive gear. Second, I removed the non-driven gear and found that the lower gear tooth edge has a 45 degree bevel on it, and the drive gear has the same. I've never seen this before in a gear pump, but could this be normal? Both gears are identical.
thanks
