IHC TD5 Crawler
Albertagary
06-28-2006 22:15:06
Hello I recently bought a TD5 that is tough to steer.How do you adjust steering clutches and brakes?
Thanks Gary
STARTER
07-04-2006 18:35:55
 Re: IHC TD5 Crawler in reply to Albertagary, 06-28-2006 22:15:06
Did you buy the TD5 with 4 roller tracks that was for sale in Riverton? That is one nice crawler.
Tom Spivak
06-29-2006 17:07:02
On either side next to the seat, inboard of the finals are two housings with the brake and clutch adjusters inside. On top is a little plate cover you take off and inside is the brake adjuster. When the levers and brake, and clutches are are adjusted properly, you pull the lever and the clutch disingages just befire the brake applies. Unless you are fairly mechanical, you should get a manual. One of the guys on this forum will have one, I"m sure.
