HD-10 Will not steer
DrewA
06-29-2006 11:34:01
I have and AC-10 and the steering clutches do not disengage. I was told that it could be the charge pump, were is the pump. What else could it possible be. Need help. Thanks
DrewA
06-30-2006 10:18:34
 Re: HD-10 Will not steer in reply to DrewA, 06-29-2006 11:34:01
That would be good if it was a strainer or filter. We pulled the pump off and check it out and it was fine. The only thing that we thought it could be was the suction line going to the pump because it had a hole in it. Also what is the filter canister for under neath the seat, The filter was removed and never replaced.
hectorgemme
06-30-2006 14:02:53
 Re: HD-10 Will not steer in reply to DrewA, 06-30-2006 10:18:34
HI The canister filter is for the oil filter and the element should be4372517 but no sure but your first probleme should be your suction line hole like you said.
hectorgemme
06-29-2006 14:39:34
HI If you have a dry stering cluch you dont have a pump but if wet stering cluch the pump should be under the fuel pump.
DrewA
06-30-2006 05:29:18
 Re: HD-10 Will not steer in reply to hectorgemme, 06-29-2006 14:39:34
What is the pump for that is on the left hand side of the motor. There is a large pump which I beleave is for the fuel and a smaller gear type pump directly behind it and driven by the larger pump. And they are wet clutches.
hectorgemme
06-30-2006 09:37:01
 Re: HD-10 Will not steer in reply to DrewA, 06-30-2006 05:29:18
HI The small pump should be the stering cluch pump and the part number not sure 620201 and check to the oil filter on transmission and should have to a strenner on left side transmission maybe stuck.
