Hi, guys. I'm a city guy that bought 10 acres, a tractor ('59 Ford 901 PowerMaster) and an '89 Construction King backhoe -- all to fulfill a few nostalgic childhood dreams. 0h, and to build a new house! I bought some books about backhoes, studied the Case operator's manual and started practicing. After a month of trouble free driveway making, tree clearing, trench digging and wreaking playful havoc with my 'hoe it just decided to stop playing. I was trenching fifty yards of ditch, going up a slight incline, then tucked in the boom, pulled up the stabilizers and put it in Forward to pull up a bit for my next few yards of trenching. However, it acted like the brake was set (it wasn't) and gave off a light smoke from under the hood. After checking the obvious stuff (hoe up, stabilizers in, no obstructions, front loader raised) and still no luck, I shut her down fearing damage to the transaxle or engine. The old girl hasn't had the best maintenance apparently since most of the gauges don't work. None show overheating, no warning lights or other indications of trouble. I've checked the coolant and other fluids (keep in mind, it is on about a 5 degree uphill slope) but can't determine any problem except it looks like the main hydraulic tank may be low (doesn't appear to show fluid in the little sight window). Do I need to buy genuine Case fluids or will the generic stuff you get at Orscheln's or Tractor Supply work? I want to be careful I don't screw something up so I came to the source - you guys, before I do anything else. Can someone get me dialed in here? I do appreciate your advice. Thanks.
