350B vs 350C
steve c
11-16-2001 07:44:31
do they have the same HP? are gears stronger in the c? I know b has dry brakes and c has wet.
Roland
11-16-2001 13:38:18
 Re: 350B vs 350C in reply to steve c, 11-16-2001 07:44:31
I currently own a 350 tractor only, 350B loader with backhoe, and a 350C tractor only, no attachments. In addition to what the 350 has the 350B got steering boosters ,engine oil cooler , larger bolts in frame to reverser, direction control lever went from dash to left battery tool box. The 350 has a 4 speed trans with reverse the 350B lost the reverse, not needed with reverser. the 350C went to wet clutch as the big change. The steering boosters got more simple. All modles I have are basicaly the same, parts are inter change able. I have had the 350 and 350C only three months so I can not say how much better or how much longer the wet clutch will last. Hope this helps if you got more questions post them and i will try to answer them.
Larry
11-16-2001 17:17:57
 Re: Re: 350B vs 350C in reply to Roland, 11-16-2001 13:38:18
About how long does the dry clutch last? Thanks.
