KOMATSU EXCAVATOR
JIM WHITBECK
07-07-2006 15:11:56
CAN ANYONE HELP KOMATSU PC80 EXCAVATOR WILL NOT SPIN PUMP HAS BEEN CHECKED OK WHEN PUMP IS OUT OF MACHINE IT DOES NOT TURN BRAKE IS ON EVERYTHING ELSE WORKS DRIVES DIGS? HELP THANKS JIM
Roy Suomi
07-09-2006 04:12:48
 Re: KOMATSU EXCAVATOR in reply to JIM WHITBECK, 07-07-2006 15:11:56
Could you be a little more exact about the problem? Is it not driving the tracks or is it the "house" not turning..Both have a brake that is hydraulicly actuated..When you actuate a lever to turn the "house" or propel the tracks , hydraulic pressure releases the brake under the hydraulic motor..These brakes have multiple brake plates and steel disks and are actuated by a piston which locks up the function when pressure is not applied to the function...
