Terry, I am in the middle of the rebuild on my 188 in my '72 track loader. Do a search on this forum and over at the Case forum for "case 188". There are several well documented troubleshooting/rebuild posts. As I found out, (and others noted as well), don't be surprised if it's a little worse than expected once you get into it. My machine was due for a rebuild ever since I purchased it, smoked, used oil, and needed ether to start all the time. I nursed it along for nearly 2 years, but it finally developed a slight knock. I had hoped it was a piston slap or valve knock problem, it turned out to be a spun rod bearing (which I think is kind of common on these engines). Ended up that my crank was trash, which is the expensive piece to this rebuild, about $650. Rebuild kit itself was $625, and includes sleeves, pistons, rings, bearings, and all the gaskets. The engine is pretty straight forward, as far as engines go. Actually, probably the most simple engine that I have rebuilt. I had done about 5 gas engines before, but this was my first diesel. As for your problem, the white smoke is puzzling, maybe fuel that's not burning due to piston or valve problems, or possibly water in the cylinder. I would start at the top and remove the valve cover, then the head. If no signs of the problem there, then yeah, pull the pan off and take a look. Hope this helps, and good luck. Jon
