D5B LGP final / sprocket seal
Workneedsdone
07-13-2006 13:41:18
What is involved in replacing the seal behind the sprocket / final drive. This machine is the size of a D6. Also does anyone have a service manual for this dozer 46x00628 Thanks
Bob Plumadore
07-14-2006 19:01:00
 Re: D5B LGP final / sprocket seal in reply to Workneedsdone, 07-13-2006 13:41:18
I can scan you the pages, I am holding on to 50+ years of cat service mauals and parts books. I some parts books and service manuals from the 30s and 40.E mail me and I will be glad to share.
Bob Plumadore
07-14-2006 06:48:03
Yes I have the Manual. unless you cat dealer will rent you the tooling and it is dangerous to use
the best way is to pull the final drive in one peice.
carry it to either you cat dealer or and indepedant undercarriage parts dealer and let them press it apart and replace the inner seals
I make it a practice to also replace the outer seal group and the large "O" ring in the holder assy.
Workneedsdone
07-14-2006 18:07:56
 Re: D5B LGP final / sprocket seal in reply to Bob Plumadore, 07-14-2006 06:48:03
Bob Plumadore, how much would you want for your mamual? I"m having trouble finding one that matches my Serial #. When you said pull the final drive assemble, what is involved in doing it this way? Also what is the best way to get the roller assembly out of the way? Any advice would be greatly appreciated.
Bob Plumadore
07-15-2006 05:02:00
 Re: D5B LGP final / sprocket seal in reply to Workneedsdone, 07-14-2006 18:07:56
all the D5 books will give you the same info. I will scan you that part of the manual the roller frame is simple but heavy,I need you E Mail address to send the scans
Bob/Ont
07-13-2006 14:53:14
It's a big job and you need pulling tools and press. Manual will explain.
Later Bob
