d-4
MI Mark
07-14-2006 19:47:47
I'm having trouble with the gas starting engine will start but won't stay running and runs at only one speed . Are there weights in the governor that could be causing this or what?
hectorgemme
07-15-2006 13:21:54
 Re: d-4 in reply to MI Mark, 07-14-2006 19:47:47
HI I am not sur but the probleme should be the governor.
TomA
07-14-2006 21:42:55
Check your fuel supply. The biggest problem with the starting engine is fuel. There is verry little fall from the tank. The original lines get plugged up. All mine run directly from the filter on the tank to the carb with 1/4" fuel line clamped on cut off ends of the old tubing
