HD3 Track links? HELP
Idaho Red
07-16-2006 13:06:45
Does any one have 2 or 4 Track links for a HD3? with or without pads the Part # 233910 is cast in each link, in the Book there #73233910.
jdemaris
07-17-2006 05:33:35
 Re: HD3 Track links? HELP in reply to Idaho Red, 07-16-2006 13:06:45
H3s, HD3s, H4s, and HD4s use the same tracks. However, early tracks have smaller bushings than later and replacement pins and bushings are not available. And, many have replacement tracks on them, e.g. Berco. I have an extra set of Berco tracks that are not going to be fixed - with dozer pads - so I don't mind cutting off some links. They were already shortened once - with one link missing from each. I was originally trying to find extra links to fix them, but wound up buying a complete set of used tracks. If you find out you can use links and/or pads from these tracks, let me know.
Idahored
07-19-2006 22:20:27
 Re: HD3 Track links? HELP in reply to jdemaris, 07-17-2006 05:33:35
If you have the track links with the 1 1/4 inch pins I want 4 with pads, Email with price and weight so I can get them on the way, The Crawler"s been setting for 2 months now. Summer"s about over, thanks Ken
Idahored
07-19-2006 22:19:49
jdemaris
07-20-2006 05:46:50
 Re: HD3 Track links? HELP in reply to Idahored, 07-19-2006 22:19:49
My old tracks are Bercos and pads are original dozer style with grouser-bar. Pads are 14" wide, track pins are 1 1/4" diameter, and the width of a track link at its narrowest - where is fits inside and adjoining links seems to be around 3 1/2". I'm leaving in two days to the UP in Michigan and will be gone for almost two weeks. So - not much I can do until after that unless I hear from you today - or you can call me or email me tonight. My ox-acet. tanks just ran out - and I'd have to get them filled so I can cut off a few links (unless you want an entire track). They are worn, though. Worn enough that a link was removed from each one to gain adjustment. The bushings are not broken through, though.
