JD 350 Dozer
Brian R.
03-19-2000 13:11:32
I have found a decent John Deere 350 Dozer with hydrualic lift blade. It has the Gas Engine. What things should I look for on this dozer. What are any weaknesses and what is a good average price? Any info will be apreciated
Thanks
Brian R.
Kirk
03-21-2000 10:46:34
 Re: JD 350 Dozer in reply to Brian R., 03-19-2000 13:11:32
These JD's typically get a for sale sign on them once them become to expensive to fix. The tracks and undercarriage are usually the most expensive parts to repair and could be the reason why it is now for sale. A complete undercarriage overhaul could run anywhere between $2000 & $5000. Good luck! Can you post a photo of it?
Mongo
03-20-2000 12:16:33
Pre '72 models have dry clutches and post have wet ones. The wet clutches are much less problems than the dry. The other three things are, undercarriage, undercarriage and undercarriage...
FRED
03-19-2000 18:28:27
Make shure all controls work. also check where main frame bolts to rear case they are know to crack in this area. FRED
