G188D Oil Pickup
Terry Healy
07-20-2006 18:48:22
I am swapping oil pans, putting a cast oil pan on an engine that had a steel oil pan. Is the Oil pickup fom the cast oil pan G188D interchangable with the one from the pressed steel pan? Can I just change the pickup over from the cast pan engine or do I have to swap the entire pump assembly. Do they have the same oil pump?
Many Thanks, Terry
John Van Valkenburgh
07-21-2006 10:33:22
 Re: G188D Oil Pickup in reply to Terry Healy, 07-20-2006 18:48:22
Terry,
My experience is similar to jdemaris. I've got a '68 model 450 loader but I think at some time it got a 188 engine that was originally in a backhoe. The loader had a big weight/guard directly under the oil pan and I'm guessing that it originally had a pressed steel pan. The engine that its got now has a cast pan and I ran into a few problems getting it out.
I recall having to grind down a small section in the front of the pan around the oil pump area. I also had quite a bit of trouble getting the pan off because it would not clear the lower crossmember and the oil pickup. I had to loosen the engine supports and jack it up a few inches. No problems though once the pan in in place. Sorry I don't know if the pickup was from an engine with a pressed steel pan or cast pan.
John
1968 Case 450
jdemaris
07-21-2006 05:01:44
I changed a steel-pan engine over to cast-iron since the engine went into my 580CK. I used the pick-up from the steel pan setup with the cast-iron pan with no problems. But . . . I did have two other problems while changing over. #1 I had to change the rear-main seal retainer by the back of the crankshaft because the original steel-pan retainer did not have the threaded bolt-holes. #2 the oil pump with a steel-pan engine interferes with part of the cast pan. There needs to be small part of the pump body ground off at an angle for the pan to fit.
JAY IN KY
07-21-2006 08:17:20
 Re: G188D Oil Pickup in reply to jdemaris, 07-21-2006 05:01:44
what is the benifit of going to a cast iron pan?
Terry Healy
07-21-2006 09:33:54
 Re: G188D Oil Pickup in reply to JAY IN KY, 07-21-2006 08:17:20
First , thanks to jdemaris for his kind assistance.
Jay, I have a Case 580B and it needs the cast pan to pick up the rear support for the front wheels. I think they put it on the backhoes so they could work in rough ground without a rock crushing the steel pan. In any case I have swapped the pans and changed over the oil pickup tubes. The cast pan had a float type of oil pickup where the steel pan had a fixed type and would not fit in the cast pan as it stuck down too far. I did not see where I would have had to grind anything on the pump but maybe the pump on the newer engine was already to fit the cast pan. I hope I'm not missing something ther, but the cast pan seems to bolt up alright. Regards , Terry
jdemaris
07-21-2006 09:49:54
 Re: G188D Oil Pickup in reply to Terry Healy, 07-21-2006 09:33:54
If it fits, then no sense worrying about it. In my case (or Case), I had the two engines sitting side by side - one that came with the steel pan and the other cast iron. The oil-pump from the steel-pan engine had no grinding marks on it, whereas the pump in the other engine had an approx. 45 degree angle ground on the outide. Without that clearance, the cast pan won't fit over the pump. The pump without the grind-marks was identical otherwise. I ground the relief on it used it. In my situation, the cast-iron pan would not fit tight against the block - it was held away maybe an 1/8" before I ground. It would make sense to me that Case would sell a "fits all applications" pump, and maybe they did. In answer to the other guy's question about pans. With many machines, e.g. the 580CK, part of the front-axle attaches to the oil pan. But, in general, in any application where debris might hit the pan, a cast-iron pan is much more durable. I've got an Allis Chalmers that had tin pans on both bottoms of the final drives and both got holes punched through them. I finally changed over to cast-iron.
JAY IN KY
07-21-2006 20:20:40
 Re: G188D Oil Pickup in reply to jdemaris, 07-21-2006 09:49:54
thanks, I have the 530 ck with steel pan. I didnt know the 580 came with a cast pan
Terry Healy
07-21-2006 16:54:12
Thanks again jdemaris.
My cast oil pan seems to bolt up alright without grinding any relief....as you had said though I did have to swap the rear-main seal retainer by the back of the crankshaft because the original steel-pan retainer did not have the threaded bolt-holes. Now I'm just waiting for gaskets and the new main seal. I can almost here it purrrr.
Thanks again, Terry
