JD 450B Wiring Diagram Needed
Uncle
07-22-2006 14:25:01
I just got the engine put into the 450B and the previous owner destroyed the wiring.
All the wires are cut and I don't know where to start.
I need the dash and engine area.
Thanks, Brian
Roy Suomi
07-24-2006 17:43:20
 Re: JD 450B Wiring Diagram Needed in reply to Uncle, 07-22-2006 14:25:01
I can copy from my tech manual..Need address to send it out..Did you ever get the 655-C Ford to shift??..I looked in my tech manual..Its all electric solenoid shifted with an electronic shift modulator to cushion shifts..The modulator is next to the steering motor [valve]. The solenoids can be accessed by removing fuel tank , top cover . The modulator has microprocessors in it..Bet thats cheap.....
