Case 188 - groove in cranshaft pulley
Fred68
08-02-2006 05:45:36
I am replacing the front crankshaft seal in a 188 diesel and I noticed a grove is worn into the crank pulley. Is this groove supposed to be there? I didn't think it was and I was going to have a machine shop weld it up and turn it back down smooth.
Fred.
Bob Plumadore
08-02-2006 06:01:05
 Re: Case 188 - groove in cranshaft pulley in reply to Fred68, 08-02-2006 05:45:36
Look in the yellow pages under bearings. most bearing adn seal dealers have what is know as a speedi sleeve it installs over the crank and it is like new again. I dont knwo about case, cat sell them for all their tractors. a lot cheaper than welding and not as likely to cause to crank to break
Fred68
08-02-2006 06:15:12
 Re: Case 188 - groove in cranshaft pulley in reply to Bob Plumadore, 08-02-2006 06:01:05
Thanks for the reply Bob. This is for the front seal and it is the pulley (damper) that has the groove in it.
Bob Plumadore
08-02-2006 08:45:50
 Re: Case 188 - groove in cranshaft pulley in reply to Fred68, 08-02-2006 06:15:12
A spedi sleeve will also work there
Fred68
08-02-2006 08:51:07
 Re: Case 188 - groove in cranshaft pulley in reply to Bob Plumadore, 08-02-2006 08:45:50
Yep, that's what my machine shop is going to use.
Thanks for your help.
Fred
