150 international parts
alan32287
08-02-2006 15:38:20
Is there a good place to buy parts for a 150 international crawler?or a website?I think its around a 1970 model. thanks for any advice.
seann
08-02-2006 16:56:24
 Re: 150 international parts in reply to alan32287, 08-02-2006 15:38:20
Depends on what you're looking for. Some parts for a machine that old you're not going to be able to get at a dealer anymore. But some stuff should still be available at a Komatsu dealer (they took over IH construction parts for Dresser, who took it over for IH). Otherwise there are a mixture of sources to look at depending on what you need. NAPA and other reputable auto parts places can get all the filters and fluids. Several suppliers offer rebuild kits for the 282 diesel. Roosa master pump can be rebuilt by most reputable diesel engine shops. Hydraulics are pretty standard, any good hydraulics shop should be able to help you with most stuff you might need (packings, seals, valves, hyd pump rebuild etc). Used U/C stuff is available, and I see new parts (sprockets/chains/rollers) floating around in online aftermarket (ebay and various const websites) once in a while. Tranny/final drive bearings can usually be bought from Komatsu or matched up from any good bearing supplier. Same thing for most seals. The list goes one and on, but there are used parts machines for sale from time to time on ebay and elsewhere quite often. Plus if you go to the redpower site referenced below, someone there might be able to come up with what you need as well. Also, keep in mind that the 150 loader is based on the TD9B dozer, so many parts are interchangeable with that model. There are also some interchangeable parts with earlier models as well (depending on what you need), like the TD9-92 and TD9-91 series loaders and dozers.
alan32287
08-02-2006 17:03:18
 Re: 150 international parts in reply to seann, 08-02-2006 16:56:24
Wow!thanks for all the info!
