JD 40 bullgear housing
gumba
08-08-2006 07:52:33
Located a JD 40 crawler with a busted left rear bullgear housing. What do you suppose caused it and how hard are they to find and replace?
Lavoy
08-08-2006 08:37:24
 Re: JD 40 bullgear housing in reply to gumba, 08-08-2006 07:52:33
The lion's share of them get broken from abuse or lack of maintenance. If the axle seal goes bad, the oil leaks out, dirt gets in, and the bearings go out. When a couple of the rollers from a bearing get carried up between the gears, something has to give, and usually it is the housing.
Lavoy
CH
08-08-2006 08:16:59
Not a hard job,depends on how rusty everything is,I have all the parts you will need,email me for my link
