TD-14 W-9 timing ?
Hunting4junk
08-08-2006 19:45:04
I Have a TD-14 that has had a gas engine from a W-9 tractor put in it using the TD-14 bell housing. it ran pretty good but lacked power. we rebuilt the engine and went thru the head and now we can't get the timing set right. when we set it where it makes good power it won't start hot. when you get it too start good it's way down on power. Looking for any help in getting this beast correctly timmed so we can start enjoying it.
Derekaz
08-09-2006 16:38:06
 Re: TD-14 W-9 timing ? in reply to Hunting4junk, 08-08-2006 19:45:04
Here's my opinion. If it doesn't wan't to start with the timing set where it is running strong, maybe the starter/ batteries are weak and won't crank the engine fast enough. Or, maybe the advance mechanism (centrifugal?) isn't working to retard the timing when the engine isn't running.
farmerron
08-09-2006 14:38:52
Check the compression on each cylinder. Back off the valve adjusting nut 1/4 turn and recheck compression. Repeat this a few times on each valve until compression comes up. Once you see compression come up evenly across the motor; then it should run.
hunting4junk
08-09-2006 16:01:00
 Re: TD-14 W-9 timing ? in reply to farmerron, 08-09-2006 14:38:52
thanks we already done all this. it runs just need to get the timing right
Tramway Guy
08-08-2006 20:14:54
Are you running a magneto or distributor?
Is it the original unit?
hunting4junk
08-09-2006 15:58:47
 Re: TD-14 W-9 timing ? in reply to Tramway Guy, 08-08-2006 20:14:54
magneto and it"s the original unit from the W-9
at least thats what we were told
