410 JD engine
BSer
08-09-2006 16:42:12
I bought a JD410 TLB today that has the engine missing. Nothing else on the machine has problems; they simply couldn't pay the machine shop and lost the engine. What else used this engine? what is the JD designation for it? Anyone know a source or have one?
motorhead460
08-09-2006 19:59:50
 Re: 410 JD engine in reply to BSer, 08-09-2006 16:42:12
I think it should be a 4219 which stands for 4 cylinders 219 cubic inch displacement. JD makes several engines that will work,4202,4219,4239,4276.They all should bolt up the same just different displacements.You can also get all of them with or without turbo.
Tom in Central Pa.
08-10-2006 04:41:07
 Re: 410 JD engine in reply to motorhead460, 08-09-2006 19:59:50
Be sure to get an older model engine block,with the smooth-looking sides. They are designed to carry the weight and stress of the tractor. The newer blocks have a vertical ribs along the sides, less metal, less strength, not good for your 410.
