td9-92 brake adjust
bcPA
08-10-2006 17:33:44
I need to adjust the brakes on my 92 series td9. I removed the floor boards and found that there is a piece of metal bolted to the brake pedel lever. This piece of metal has a curved groove like a generator adjusting bracket. The bolt goes thru the groove and into the pedel arm. I assume that is how to adjust the brakes. Am I right and are there threads in the pedal arm or is a nut and bolt used with the nut on the other end of the bolt. I have tried to turn the bolt head but cant break it loose. Any suggestions will be welcomed. Thank You.
hectorgemme
08-11-2006 03:11:20
 Re: td9-92 brake adjust in reply to bcPA, 08-10-2006 17:33:44
HI For break adjustement remove the stering break inspection cover from bottom side of the main frame and loose the jam nut and turne the turnbuckle until the break lining contacts the cluch drum for it full length and wnen the break pedal is height and dont forget retighten the jam nut.
