? for hectorgemme
Dale L
08-11-2006 09:26:25
Hector do you think 15-40 delvac engine oil will work for the wet clutch on a AC HD-6. Thanks Dale L.
Dale L
08-12-2006 06:23:45
 Re: ? for hectorgemme in reply to Dale L, 08-11-2006 09:26:25
thanks for all the input. I think I'll go with 30 weight oil.
hectorgemme
08-12-2006 03:08:24
HI I had 2hd 11 and 5 cat.d7 with wet cluch and use the motor oil for the cluch and friend of mine use automatic transmission and scrap the pump.
hd6gtom
08-11-2006 19:50:08
Dale; I have my book here and it says "On tractors equiped with an oil type clutch, a good quality Automatic Transmission Fluid "type A" purchased from a reputable oil company is recommended for all atmospheric temperature ranges."
hectorgemme
08-11-2006 11:07:16
HI I am not a expert but my friend use same oil than he use for the motor.
HECTOR
j watkins
08-11-2006 10:11:14
I,m not Hector but no it is not what you need two heavy for pumps and filter you need STREIGHT
30 WT AND WOULD BE GOOD IF YOU COULD FIND NON-DETERGENT OIL SCOND CHOICE WOULD BE A CHEAP 10 WT LIKE R&O HYDRAULIC OIL BUT IN HOT WEATHER THAT WOULD BE A LITTLE TOO THIN 10/30 OR 30 NO 15/40
