TD 340 need help with an engine problem
TracTracTor
08-13-2006 22:29:01
I was digging around a large stump and working it pretty hard when something inside let loose. I don"t think it was a rod or cap. The sound was more like a small bell. A pinging or tinging sound. With erratic puffs of smoke. I thought maybe a piston skirt had broken off. I was told that an injector might have come loose inside and was rattling around. Can anyone shed any more light on this problem?
Bob Plumadore
08-14-2006 06:52:50
 Re: TD 340 need help with an engine problem in reply to TracTracTor, 08-13-2006 22:29:01
I would pull the head, you may not have much of a problem. that is a not to expensive an engine to rebuild especially if you use after market parts. I would get the head reworked and buy the parts through the machine shop that did the head work.
oldfarmboy jim
08-13-2006 23:06:01
my best guess would be a combustion chamber liner or piece of it. Especially possible if you use ether or starting fluid on a regular basis. Whatever it was, you"re probably going to have to remove the head to investigate. Good luck with it.
TracTracTor
08-14-2006 00:45:32
 Re: TD 340 need help with an engine problem in reply to oldfarmboy jim, 08-13-2006 23:06:01
Thanks Jim I didn't think about the liner. Would this be just the edge of the liner and not get in to the water jacket? I guess in time I will get around to it. I might start looking for a replacement motor and not worry about a rebuild. It sure was a good worker when running. I miss it a lot.
