Terratrac head gasket replacement
TracTracTor
08-15-2006 14:35:17
I'm going to attempt replacing my head gasket on what I think is a 320 track loader. It has a Cont. F162. I've got bubbles in the radiator and low power. I haven’t run a compression check as of yet and probably won't since no mater what the head needs to come off. Does any one have any idea what I might run into? What else should I do while I'm there? And is this a common problem with the Continental fours? Thanks much for any help
george md
08-16-2006 09:28:45
 Re: Terratrac head gasket replacement in reply to TracTracTor, 08-15-2006 14:35:17
Before you completely comdem the head gasket, slip the fan belt off ( loosen ) and see if the bubbles stop . If they stop you most likely have a water pump seal letting air in around the shaft. If they continue then pull the head . If you mark distributor and drive locations , and don't turn the engine
you should be able to put them back in and be in
time. link below to case-terratrac club
george
