case 450 keeps losing prime
billdeere
08-15-2006 14:35:56
my case 450 loader charge pump sometimes wont hold a prime and i have a hard time priming it again whats the best way to prime the pump i have been taking off the filter end of the hose and filling it up and then putting it back on and firing it up sometimes it works sometimes not i am trying to find a new hose from the filter to the pump the one thats on it is hard and old and doesnt tighten down very well anybody know what type of hose i should use thanks for any help Bill
butchtn
08-18-2006 04:30:17
 Re: case 450 keeps losing prime in reply to billdeere, 08-15-2006 14:35:56
george
i dont have a serial number the one the dealer where i bought it put a number on a tag and tied it to the dozer but its for a newer model all i can tell you for sure is that it has a 188 eng in it
thanks
BUTCHTN
08-17-2006 04:54:33
GEORGE WHERE DID YOU GET THE SEAL
BUTCH
george md
08-17-2006 22:58:01
 Re: case 450 keeps losing prime in reply to BUTCHTN, 08-17-2006 04:54:33
Butch,
The seal in my 1000 case dozer got hard and
very difficult to prime ,and in the 1000 the seal was a trostel seal and no longer made by
trostel. I found a CR seal with the right shaft
size but larger OD and I bored the housing to fit.
I looked in the parts book for a 450 and the seal is listed there . But that doesn't mean you have to go to case to get it as it most likely can be
had from a bearing and seal warehouse . Give me a ser # and I'll look up the seal # and see if I have a cross reference # for it . Send it in the email .
george
butchtn
08-16-2006 04:37:44
WELL BILL I HAVE THE SAME PROBLEM,BUT WE'RE NOT ALONE.YOU CAN GET THAT HOSE FROM A CASE DEALER AND NOT THAT EXPENSIVE OK BEST WAY TO PREVENT LOOSING PRIME IS TO PARK IT ON A SLIGHTLY DOWN HILL ADDITUDE IF YOU PARK IT SLIGHTLY UP HILL YOULL LOOSE THE PRIME YOU PROBABLY NEED A NEW PUMP
BIG BUCKS
george md
08-16-2006 09:14:07
 Re: case 450 keeps losing prime in reply to butchtn, 08-16-2006 04:37:44
Butch, The pump may not be worn out, if the shaft seal wears it will give you the same symptoms. A new seal may cure your troubles .I have have the same problem on case 1000 ( same design system ) , new seal cured the trouble.
george
