JD 300 backhoe sump screen problems
Mark Thomas
08-21-2006 10:19:57
Bought this unit a few months ago, and the hydraulics were very slow. Haven't had much time to work on it. Started this past weekend, changing all the fluids, filters, etc. Went to check/ clean trany sump screen, and it won't come out more than 2-3 inches. It was covered in dark brown goow. Acts like it is hanging up on something inside. Worked on trying to get that screen out for 45 minutes, but no can do.
If I really force it, and the screen tears, I'm worried it will tear the rear steel rings off and those will be stuck inside the trany. Any help, tricks or suggestions ?
Roy Suomi
08-21-2006 20:43:40
 Re: JD 300 backhoe sump screen problems in reply to Mark Thomas, 08-21-2006 10:19:57
I believe there's another plug to remove on the other side of trans case..Been a while since I've been there...
Case450
08-21-2006 16:22:01
I'm not familiar with that machine so i'm just throwing this out there but would it be too much to remove the sump assembly and clean the whole thing? That way if gunk falls inside you can clean it out. Also it might worth checking out if the screen is that clogged. Like I said I'm not familiar with your machine nor am I a mechanic, just throwing that out there. Good Luck!!
