Where is serial number on HD-4?
Randy Howard
08-23-2006 17:13:15
I have an Allis Chalmers HD-4 track loader that I need to identify. Where do you suppose the serial number etc. is? I read another post that said on the front frame (I think) but I have looked all over the front of the thing by the grill and can't find anything.
Randy
indiana allis
08-24-2006 19:13:20
 Re: Where is serial number on HD-4? in reply to Randy Howard, 08-23-2006 17:13:15
HD4 serial number will be on the front (facing up) across the frame in front of the grille.
You'll probably have to scrape some paint and/or dirt to see it.
John
Dale(MO)
08-23-2006 20:50:43
If it's the same as the HD3, it should be on the left side (while sitting in the seat), on the bellhousing flange. It will be stamped, and not that deep. You may have to scrape the paint off to see it. Hope this helps.
Good luck,
Dale(MO)
