Breaking loose stuck track adjuster?
Randy Howard
08-26-2006 11:37:58
Hi all,
I have two stuck track adjusting rods on my Allis Chalmers HD4. They are 1-1/2" hex rods about 3" long with threads on one end. I got one to turn a little using a Rigid off-set hex wrench and a pipe cheater but the other one won"t budge. I think what I really need is a special wrench that grabs more of the hex so I don"t knock the corners off as I am doing now. Maybe a two piece hex that I can bolt together somehow?
Any suggestions on how to grab this hex better or other tricks to try?
Randy
jdemaris
08-26-2006 16:03:32
 Re: Breaking loose stuck track adjuster? in reply to Randy Howard, 08-26-2006 11:37:58
I've had some that were so rusted and stuck, it was easier to make new adjuster out of hardened rod, 1 1/2" diam. by 6 threads per inch. The original wrench, I believe is a 2 3/16" which is kind of an odd-ball size. I'd first try loosening up the lock-nut strap (not the adjuster nut). Then heat the adjuster nut with a torch until it starts to get orange, and then pour cold water on it.
