D4 or R4?
Yliopisto
09-05-2006 18:55:27
We bought what is supposed to be a D4. The decal on the left side gas tank says so and on the front of the radiator there is an off-center D4, but there is a letter or something that's been ground off and painted over. The Tractor number is 6G37, suggesting an R4, but it's a diesel tractor with a handcrank pony engine. A tin plate on the left side of the engine says something about the fuel system and has a 7-P number. Any ideas what we've got?
Old Magnet
09-10-2006 08:48:55
 Re: D4 or R4? in reply to Yliopisto, 09-05-2006 18:55:27
On the Radiator Logo:
The R part of the RD4 designation was dropped during production of 1939 and became the D4. The 4G5736 sr. no. was a 1937 unit. Someone may have tried to "update/match" the later model designation by grinding off the "R".
Old Magnet
09-09-2006 20:26:32
The R4 -6G series is a gas engine produced from 1941-1944
The RD4 - 4G series uses the D4400 engine and was produced from 1936-1939 followed by the 7J series.
Yes the serial numbers originally matched but you have the diesel D4400 engine mounted up to a original 6G transmission case. Nothing wrong with that once you know what you have.
hectorgemme
09-06-2006 03:36:05
HI This machine is R4 SERIE 6G and I have a parts book.
Yliopisto
09-06-2006 11:32:28
 Re: D4 or R4? in reply to hectorgemme, 09-06-2006 03:36:05
So, the R4 Series 6G is a Diesel with a handcrank gas pony engine? Why would someone put D4 decals on it and then the front of the radiator have something ground off, leaving the D4 intact? How would I know if it is maybe a newer D4 engine? Any idea when the 6G was made? Thanks for your response.
TomA
09-06-2006 13:36:33
 Re: D4 or R4? in reply to Yliopisto, 09-06-2006 11:32:28
Is the starting engine mounted behind the diesel or is it along side? How many cylinders does the diesel engine have?
Yliopisto
09-08-2006 15:41:27
 Re: D4 or R4? in reply to TomA, 09-06-2006 13:36:33
The pony engine is to the rear of the diesel engine. It is a 4-cylinder diesel.
Yliopisto
09-09-2006 19:12:22
 Re: D4 or R4? in reply to Yliopisto, 09-08-2006 15:41:27
Thanks for direction to the Tractor Number on the engine. I couldn't find it. It had been painted and was tough to see. I found the Tractor Number 4G5736 there. So on the back of the tractor the Tractor Number is 6G37. Should these match? Or did they originally?
hectorgemme
09-06-2006 12:30:41
HI I am sorry the r4-- 6g is a 4 cylinder gas engine and if yours is a diesel with poney that should be a d4 serie rd4 and you should find the serie number near the small housing transmission cluch and on the back main housing left side near the pto hole.
