Cat D2 pony engine locked up
Jay Oakes
09-06-2006 09:31:44
Can anyone help with Cat D2 pony to main engine pinion? It seems to be bound up-took it loose and hit it with a hammer and it didn't move. Main clutch is locked up-can't move it. Diesel engine did run and turns. Doesn't seem too be any lube in pinion assy. Levers to engage pinion and pinion clutch seem to be locked up.
R wooley
09-08-2006 18:21:18
 Re: Cat D2 pony engine locked up in reply to Jay Oakes, 09-06-2006 09:31:44
pony to diesel drive gear once engaged will not release until diesel is running (flywheel drive on pony will disengage when it rotates at high speed) I have had the flyweight mechinism come apart short lever engages drive pinion longer lever engages clutch assembly on side of motor.
