D4 not getting fuel
D Brown Utah
09-07-2006 16:01:56
Ive got a 1945 D4 it has been sitting for a few years. im not getting fuel out of the injector lines. It does not show any fuel press. I am getting fuel from the bleed screw on the filter housing. Help what do I check next? any ideas
thanks
MI MARK
09-12-2006 16:41:05
 Re: D4 not getting fuel in reply to D Brown Utah, 09-07-2006 16:01:56
CHECK FUEL IN TANK THEN SEE IF FULL FLOW FROM LINE AT FILTER HOUSE THEN CHANGE FILTERS THERE ARE DEPENDING ON AGE BLEED SCREWS ON THE INJECTORS LOOSENING LINES WILL ALSO WORK CHEK FOR LEAKS ON LINES OR DAMAGE TO BLEED SCREW OR MISSING GASKETS ON FILTERS LETTING AIR IN SYSTEM.
hectorgemme
09-09-2006 02:03:42
HI The fuel pass by the filter before the pump and if the filter housing is empty ou should disconnect the fuel line to the filter housing you will see if the fuel comming full line and loose the cap tank.
D Brown Utah
09-08-2006 17:04:27
Help I went to start it tonight and the fuel filter was empty where would the fuel go. is there check valves in the lift pump? where is the lift pump?
thanks
D Brown Utah
09-08-2006 06:18:53
PS when I took the fuel filter out it was only about 1/4 full of fuel. it took about 10 min turning it over to get the fuel out of the bleed screw. is there any secrets on bleeding this motor?
thanks
MSM
09-07-2006 16:32:44
May have to pull the cover off the side of the injection pump and see if the rack is sticky,or stuck. Maybe check all the fuel lines going to the pump also for gummy deposits in the fittings.
