Weight of JD Dozer...PICTURE
Tweeter
09-07-2006 19:40:22
third party image
I am told that this dozer is a '68 or '69 JD 450 by comments from people on this site. I have not gotten any serial numbers yet for it. Can anyone verify the model for me. I also need the weight of this because we have to transport it to my shop soon.
Old Dreams
09-12-2006 20:25:58
 Re: Weight of JD Dozer...PICTURE in reply to Tweeter, 09-07-2006 19:40:22
I am seriously looking at a 450 W/ endloader and have the serial number from under the seat. It is: 1065311 and is type: 15E3M. It has a Hi-Low-Reverse down in the lower midle. Can anyone tell em the year of this unit?
How much did a typical Endloader unit weight?
Thanks!
John Wood
09-12-2006 21:14:47
 Re: Weight of JD Dozer...PICTURE in reply to Old Dreams, 09-12-2006 20:25:58
Your machine is a 1970 and should weigh in at around 13,00 - 14,000 lbs I believe.
HTH.
J.
OldDreams
09-13-2006 09:59:53
 Re: Weight of JD Dozer...PICTURE in reply to John Wood, 09-12-2006 21:14:47
Thnak you very much!
DGH
09-08-2006 18:19:47
My book says 14,170 lbs
Tweeter
09-09-2006 06:44:12
 Re: Weight of JD Dozer...PICTURE in reply to DGH, 09-08-2006 18:19:47
I have the serial numbers for the dozer now. The tag under the seat has SNT 5F3M029179T. The motor has the numbers T24961 raised on the block up on right hand side near oil dipstick. Where can find model and year?
CH
09-09-2006 08:45:38
 Re: Weight of JD Dozer...PICTURE in reply to Tweeter, 09-09-2006 06:44:12
If it is a 450 then it is a 1966.
Tweeter
09-09-2006 11:04:22
 Re: Weight of JD Dozer...PICTURE in reply to CH, 09-09-2006 08:45:38
From looking at the pictures, I cannot tell where the battery is located. Where is it?
CH
09-08-2006 05:05:22
When you get her back to the shop i can help you with parts (used and new) and manuals. Email me for my link
jdemaris
09-07-2006 19:59:49
I can't tell too much from the photo, but it looks like an early machine - maybe around 1966 or 67? The first couple of years of 450s, the shifter for the HL-R transmission was down low - between your legs, and the newer models had it up high on the side tank. The crawler with outside blade should be around 13,000 lbs.
Tweeter
09-07-2006 19:40:56
Tweeter
09-07-2006 19:42:08
 Re: Weight of JD Dozer...PICTURE in reply to Tweeter, 09-07-2006 19:40:56
maybe
