what is this lever for
D Brown Utah
09-10-2006 19:53:32
I got my D4 running today. on the left side below and behind the decompression is a lever what is it for. when it is running and I try to ingage it all I get a grinding sound. again what is its purpose in life?
thank you
oldcraneguy
09-12-2006 17:04:20
 Re: what is this lever for in reply to D Brown Utah, 09-10-2006 19:53:32
If memory serves, (big if) you should have bout 5 levers, pinion,high/low,clutch,compression release and engine throttle...seems to me theyre function was cast right into the handle of the clutch/gear/pinion levers...if you got more levers than that its sumpin I aint seen...course theres lots I aint seen....
D Brown Utah
09-11-2006 18:47:25
No I got the pony motor started and started the diesel motor with it. the diesel motor sounded good it has not ran in about 4 years.
ksb
09-11-2006 17:56:32
DBrown Utah.
"I got my D4 running today. on the left side below and behind the decompression is a lever what is it for. when it is running and I try to ingage it all I get a grinding sound. again what is its purpose in life?
thank you"
How you get it running? By pulling it?
Dave Mello
09-10-2006 21:40:14
CARUMBA !!!!! Don't DO that!!! That lever is to engage the drive pinion of the starting engine to the ring gear! The vertical lever is the starting engine clutch and the horizontal lever is the pinion. What you are doing is grinding off the teeth that you'll need in order to use the starting engine to crank the diesel....YOW!!!!
