cable weak adj.?
U9 U9 CAT
09-14-2006 12:14:36
I haven"t gotten a book yet for my old cat 56 9U D6 CABLE BLADE.. My cable seems to be getting weak, I just change the oil and it"s leaking a little just a tad over full.
When I"m moving trees my blade don"t want to pick up? I"ve just started running it real regular, And hope that it just needs some adjusting.. How do I go about that? The blade still works just when I put it in a bind it seems weak.
Thanks Mike
Bob Plumadore
09-15-2006 17:02:07
 Re: cable weak adj.? in reply to U9 U9 CAT, 09-14-2006 12:14:36
I will try and remember how to adjust the clutches on a CCU but first I would splash a guart of mineral spirits into the lining area , it sounds like you have oil getting into the clutches
this should help. try not to overfill the lube tank. it is a job to tear down the unit and replace theseals
I have added automatic transmission stopleak to them to get one to stop leaking
