Allis Chalmers 7G
Francis II
09-17-2006 19:07:36
Hi can anyone help me? I have a Allis Chalmers 7G crawler loader that is getting transmission fluid in the left final drive. It appears to happen when using the left steering lever. The tractor serial # is 22652. I would appreciate any ideas or comments on how to correct this problem or what might be wrong with it. Thanks!
NC Wayne
09-19-2006 21:00:08
 Re: Allis Chalmers 7G in reply to Francis II, 09-17-2006 19:07:36
I have to agree with Hector, sounds like the pinion seal. Dad used to work for the A/C--F/A dealer back in the 70's when the 7G's were still really common. I remember him saying more than once that when the pinion seals started to leak and he opened them up for a repair he usually found the pinion bearings were worn and that was the root cause of the leak. One thing I also remember dad saying was that when the leak started you'd better not wait too long or what would typically be a "not so expensive" repair can become really expensive. The oil entering the final drive housing tends to severely thin the gear oil and that's something the bearings and gearing in there can't stand for very long. Hope this helps, Good luck.
hectorgemme
09-18-2006 03:11:41
HI I am not sur the HD7G transmission and stering cluch oil are same lever and you said the oil transmission oil go in final drive it only one way it is by the top pinion oil seal and I dismantle 4 hd7 for parts.
