Case 480C engine removal
CR
09-19-2006 07:58:48
I have a Case 480C backhoe with a spun crank bearing. The engine will need to be pulled for a rebuild. Can the engine block be removed without taking out the entire torque convertor and power shuttle assembly? Any suggestions appreciated.
Thanks
David Manring
09-23-2006 04:14:17
 Re: Case 480C engine removal in reply to CR, 09-19-2006 07:58:48
Yes it will come out at the back of block.The coverter will be on the back of the motor like on a car. I have one down and can send you pics if that would help
CR
09-23-2006 12:50:37
 Re: Case 480C engine removal in reply to David Manring, 09-23-2006 04:14:17
Hi David, photos of the engine removal would be very helpful.
Thanks
Bob Plumadore
09-19-2006 09:55:10
rod bearing or main?
In the Atlanta GA area we are fortunate to have a gentleman who can turn most rod throws in the frame.yo have to take it down for him,remove the head, oil pan and affected piston. Also the starter as he uses an eletric motor to turn the engine.
