310a starter relay
JREX
09-20-2006 15:32:25
Was working the machine for about 20 minutes and engine quit. Turn the key, hit the start button and a wire connected to the starter relay jumps and you can hear a click. If you cross the starter witha screwdriver the motor will turn over but not start. there is fuel. I did not check for fuel making it to the injector pump yet, but i am thinking it is more electrical.
Any idesa?
Thanks, JREX
Roy Suomi
09-21-2006 17:03:12
 Re: 310a starter relay in reply to JREX, 09-20-2006 15:32:25
Sounds as if there might be a couple of problems there. If there's no current [voltage] going to the injector pump solenoid with the key on ,you might have a short in the wiring causing the dasboard circuit breaker to pop..Also check for current at the starter small wire to see if there is current going there to energise the solenoid. If there is current there and all the battery terminals are good and clean and the large terminals on the starter are clean..Sounds as if you need a new solenoid there..
