JD350C Leaking oil
sminnick
09-24-2006 06:12:14
I just bought a JD350C, according to the serial number it is an 84 model. It has oil leaking from the reverser to the transmission. I suspect a bad seal. Is there anything else I should be looking at? Everything seems ro run fine as long as there is fluid in the reverser. Thanks for any help you could give me. Steve
sminnick
09-24-2006 18:09:10
 Re: JD350C Leaking oil in reply to sminnick, 09-24-2006 06:12:14
Thanks. Will it hurt to run it with the trans fluid over full? When I run it the reverser fluid goes down and the trans fluid overflows.
jdemaris
09-24-2006 06:37:16
It was a very common problem when C series came out - with the first wet-steering clutches. One of your steering-clutch packs or steel-lines is probably where the leak is. They get their oil from the reverser. As long as you can keep up with the oil-transfer - I'd use it and not spend the money on fixing it yet. Just keep in mind, the reverser only holds around 3 gallons - and if it gets too low - you could wipe out the internals in the reverser along with the steering-clutches - and that would be very-big dollars.
