water in fuel
naz
09-24-2006 10:05:52
Hi folks,I had my HD6(4 cylinder Buda) running the other day to have it quite.Found the bowl to have water in it,drained until only clean fuel came.It started for about 10 seconds then quite.Everytime I tried it would run then stop.(about 10 times)Now can't even get a kick from it.Battery is starting to drain so I don't have many tries left before I have to recharge batterys...any thoughts or suggestions would be appreciated,
Naz
JD dozer mike
09-25-2006 18:26:14
 Re: water in fuel in reply to naz, 09-24-2006 10:05:52
Drain everything and start over, tank,filters,lines,carb, easiest /best way.
Naz
09-26-2006 03:27:21
 Re: water in fuel in reply to JD dozer mike, 09-25-2006 18:26:14
Thanks Mike,I will do that.I put some methyl hydrate in the tank and drain the filter,opened one of the lines going into injector and turned it over until I saw fuel,thought that would do it.Will drain everything,just put 10 gallons of fuel in her...
Thanks again,
Naz
