Int'l. 500 dozer won't move
davids
09-25-2006 04:29:15
My neighbor"s got a 500 dozer that just stopped pulling. If you engage the reverser you dont feel anything,either forward or reverse. Cant even make it grind a gear if you engage the reverser first and then shift the gearbox. Does he have a bad converter? Model # 500 D 40 Serial # H 3404 S Any help is appreicated. Thanks, davids
Tom Boggs
09-27-2006 18:47:55
 Re: Int'l. 500 dozer won't move in reply to davids, 09-25-2006 04:29:15
Hey David I have a 500c that did the same thing once and it was only low on transmission fluid. Have you checked that? It may also be the pivot at on the bottom of the reverser block. Sometimes it looks like its working but may not be. Check those things and maybe you'll get lucky.
Milton
09-25-2006 08:18:51
Good Morning David, --- 25 / Sept. / 2006 ---
Your friend's International "500(D)" was made at the IH Plant in Hamilton, Ont., Canada.
The Serial Number "H3405S" was made in 1967.
There will be somebody along to answer the rest of your questions.
Regards, Milton
