hd6 fuel filter change...
naz
09-30-2006 08:08:45
Hi folks,I change 2 fuel filters in my AC hd6(1960)How do I go about bleeding the lines.Air bled from filter from tank OK,but nothing in return filter.I opened one line on motor and have fuel there.I don't see a air bleeder on injector pump or manual primer on the lines....
Anyone with firsthand knowhow,
Thanks for any help,
Naz
jdemaris
10-01-2006 07:06:29
 Re: hd6 fuel filter change... in reply to naz, 09-30-2006 08:08:45
Direction of fuel is from the tank to the first filter - then to the fuel transfer-pump, then pressurized fuel goes to the second filter - and then to the injection pump. The first filter is bled by the vent screw on top - and it fills by gravity. The second filter is also bled with the vent screw on top - but with the engine cranking until all air escapes - since it receieves fuel under pressure(around 5 PSI).
naz
10-03-2006 04:11:23
 Re: hd6 fuel filter change... in reply to jdemaris, 10-01-2006 07:06:29
Thanks JD,have the filters full of fuel and have fuel up to injectors,still nothing.The fuel in the filter cannister was very dirty,could I possible have plugged injector before new filters went on??
Thanks again,
Naz
